Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-06-2008, 05:02 PM   #1
Rick Norwood
Rick Norwood's Avatar
Rick Norwood Normal reputation
2000 Jimmy Driver Window stuck shut
2000 GMC Jimmy 2wd 4 Door 4.3L. My problem just started last week. Driver's window was down and pushed the button to close it and it closed normally. When I went to open it again later, it would not move. The switch just clicks. From the few posts on this forum that even mention it, the various parts are not cheap nor are they fun to Remove and Replace. I was told the the Master Window Switch on the driver's arm rest has a circuit breaker in it and what I am actually hearing is the circuit breaker tripping when I hold the button down, probably due to a defective motor. Has anyone had to deal with this issue?
"IF EVERYBODY IS THINKING ALIKE, THEN NOBODY IS THINKING"! - Gen George S. Patton Jr.
Rick Norwood is offline   Reply With Quote
Old 10-06-2008, 05:18 PM   #2
Leeann94astro
Leeann94astro Normal reputation
Re: 2000 Jimmy Driver Window stuck shut
Yep, but not on a 2000. I just did it on my '93 Bravada. If it's the same sort of thing, there's excess grease inside the motor that heats up and drips down onto a bi-metal 'breaker', tripping it. You can't move the window again until it's cool.
I got my window motors on eBay - the place had a 2-for special (both fronts were bad). And, even with shipping, the 2 cost less than one in the local store.
I found step-by-step pictures online, specific to 1st gens, and got it done reasonably quickly. We had the help of an pneumatic die grinder to grind off the heads of the rivets, though. The rivets that hold the assembly to the door are rather beefy. The rivets that hold the motor to the regulator/track aren't and could have been drilled out with a cordless drill.
The replacement motors came with bolts & nuts to attach the motor to the regulator/track, but I had to find bolts to attach the assembly to the door.
It's not fun, but it's not terrible.
Leeann94astro is offline   Reply With Quote
Old 10-06-2008, 05:34 PM   #3
Rick Norwood
My problem must be slightly different. The window won't move no matter how long it sits or how cold it is.
Old 10-06-2008, 06:41 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Could be switch or motor and some times wiring.
The circuit breaker should be left side of dash fuse box area.
The left front door wiring also shows a express down module.
Not sure it it is part of master switch or seperate.
To check motor or switch the Dark blue and brown wires to motor should have power and ground.
To go up or down the switch reverses power and ground on the two window motor wires.
A good old type bulb test light should test it.
Let us know how it goes.
If wiring is needed let us know.
Good Luck
MT
MT-2500 is online now   Reply With Quote
Old 10-08-2008, 03:41 PM   #5
just4phun
just4phun Normal reputation
This happens to me now and again. Seems to get stuck when closed ... I can hear the motor clicking if I hold down the button for a few seconds. I never fixed it because a few days later it starts to work again ... something must be causing it to jam, but I guess a few slammed doors and it gets unstuck ... not much help I know but maybe try slamming the door a few times see if that helps.
just4phun is offline   Reply With Quote
Bookmarks
Google
Web AF
