Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-05-2008, 08:54 PM   #1
Dngrsone
Dngrsone's Avatar
Dngrsone Normal reputation
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Timing off-- did I skip a tooth on the distributor?
I rebuilt a 2.8L V6, 1988 vintage. I finally managed to get it running, but when I have the timing mark lined up right it runs like garbage. If I adjust the distributor cap until the engine runs more or less smoothly, then the timing is way off, like 120 degrees.
So, the question is, what did I screw up? I'm thinking that I managed to get the rotor out of phase. Any suggestions?
1997 Windstar 3.8 liter
Replaced Head Gaskets
1988 S-10 2.8 liter
Full Rebuild
Dngrsone is offline   Reply With Quote
Old 10-06-2008, 10:51 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Timing off-- did I skip a tooth on the distributor?
Get no one piston at TDC compression stroke.
Then point the dist rotor to no one plug wire.
Does the crank timing mark read/point to TDC cover mark when the piston is at TDC?
Some times the crank damper mark may be sliper/off or two sets of marks.
MT
MT-2500 is offline   Reply With Quote
Old 10-06-2008, 08:30 PM   #3
Dngrsone
Dngrsone's Avatar
Thanks, MT. Hopefully tomorrow I will be able to get in there and do TDC and check the rotor alignment. Someone also suggested I check the plug wires again and make sure they are in the correct firing sequence.
1988 S-10 2.8 liter
Full Rebuild
Bookmarks
Google
Web AF
