p225/70/r15 on a 2002 venture?
d768
10-01-2008, 09:04 PM
can it be done? i have some left over from me jeep. will they fit? break anything?
i think i have p205/70/r15 right now.
thanks
dewaynep
10-02-2008, 08:57 AM
The original tire size for that was 215/70-15. If you go to http://www.csgnetwork.com/tireinfo4calc.html you will see the difference in size. I think you may be a little too wide, but they may fit. The circumference is only 2% difference so you should be OK there. I think the true test would be to try them on the front and see if they interfere with a full lock to lock turn.
merc81
10-02-2008, 10:35 AM
My buddy has 'em on his 99 venture. Its tight, but they fit.
rockwood84
10-03-2008, 12:44 PM
they will be a little taller 1/2 " or so being 225 but being a 70 series they will be the same width.. i put a set of 235/60/15s on my '99 and talk about cornering.
dewaynep
10-03-2008, 12:52 PM
Um, they won't be the same width. 225 is the width (225mm), 70 is the aspect ratio of width to sidewall height expressed as a percentage or in other words the sidewall height is 70% of the width (70% of 225mm or 157.5mm). If you follow the link I posted you can see the differences.
d768
10-03-2008, 06:39 PM
well, i looked it up. i hope itll be gonna be ok. 235 is just too much lol...but between 98 and 2000 something nothing much changed right?
thanks
2000oldsilh
10-03-2008, 10:29 PM
225:25.4x.70x2+15=27.4" Thats the formula I use to figure out tire size difrence. That tire will be .5" taller.
rockwood84
10-04-2008, 09:41 AM
are you sure because a 235/60/15 is an inch wider and same height as a 215/70/15. i was always told first three numbers height /second set width /third set rim size. so a 225/70/15 would basically be the same width as 215/70/15.this is one size up not a lot of difference in width just heigth `1/2"
