new fuel pump new relay still no startblazin911 09-29-2008, 02:39 PM 95 blazer vin w pump was not responding used test terminal under hood driver side no dice checked relay had it checked by auto store no good so i replaced pump and relay. pump now works have pressure at the shrader valve waiting on guage to be brought to me to check psi. still no start can someone please tell me other possibilities this is a favor for a friend. thanks to all ahead of time i know u guys are great when it comes to these blazers and so forth. took the valve off of the top of the plenum and the smell of gas is very obvious regulator or whole unit please help its for a friend thanks to all gatoratoy227 09-30-2008, 06:37 AM it sounds like you're not getting any spark disconnect the #1 spark plug wire and put a test plug in it ground it some where on the truck on metal of course and have some one crank it the sprak (if any) should be blueish-white in color and have a snaping sound to it that would be your best place to start Automotive Network, Inc., Copyright ©2012
