Re: 88 Tercel Problem, Any Help?
I'd suggest a compression check, but depending on the kind of fuel or oil treatment you used, some of them do cause some whitish smoke (Seafoam in particular) as it is working. Eventually, it goes away.
Another question...does the smoky exhaust smell like burning coolant? It would have the same sweet smell if so. That would indicate a slight head gasket leak (the compression check might show this as well)
Some states have visible smoke emissions tests, some don't and just rely on the NOx and HC tests. If they show you the specific results, it can help diagnose what your car is burning at high revs to cause the smoke.
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
