got problems and not alot of cash
bigd7315
09-27-2008, 01:22 PM
I got a 93 jeep grand cherokee 4.0 auto with 175k on it motor was rebuilt 35k ago it gets poor milage around 12 city it doesn't have the power it should I have done new cap rotor wires and plugs new fuel filter and it is steadily getting worse it runs fine for a while then when you go to take off from a light it just boggs down like half power you can floor it and when it gets over 300 rpms it usually takes off then when it shifts it will bogg right down again till 3000 rpms again don't know alot about jeeps I am a chevy man would rather have a s10 blazer with the 4.3 any day but this is what I got and got to get it running right I read the heads where bad to carbon up so I did the marvel mystery oil and drove it around a little bit with slight improvement I also gutted the cat thinking it was clogged this jeep was a roll over and has been repaired it has other issues to like the windows only the driver switch works the windows except one it doesn't work at all if you press the driver switch and window rolling down and if someone hits there switch it will stop the window from moving the over head console isn't working either and the horn doesn't blow and the abs light is on but the brakes stop fine any help on any of these problems will be appreciated
bigd7315
09-28-2008, 10:32 PM
get this the fuel pump was going out replaced it today and 2 more problems now the fuel gaugfe doesn't work and the ignition key assembly broke so no I got those 2 issues now the fuel gauge is vewry impoertant I replaced the fuel pump assembly and it was a direct replacement for 274.00 from advance tried the pump only for 100 and it was totaled different from the factory already replaced this assembly thinking the sender wasn't working any ideas on why gauge isn't working and the switch well it quick cranking had to push the bar by hand a little farther for it to crank it runs fine revs fine and has alot of power that it never had before but I have these 2 to fix now on top of the windows issue any help
laloquera
10-03-2008, 02:46 AM
I feel you bro, your mileage is pathetic. I also have a 93 JGC, it was giving to me. When I first lay eyes in on it, I swear it, chickens had been living in it. I took everything out, down to the shell and washed and vacuumed everything. It had a head gasket seal blown out, crack exhaust manifold, punctured radiator, bad cat. I didn’t go shopping, I went picking for my parts. I got the jeep running in six days, spent $230.00 to @ $250.00. Pulled my head off, took it in to be check, spec, & magnetized. Came back and torch it down myself. My power windows switches, could not even find them on the jeeps, pulled them right out of a Plymouth voyager van, Chrysler has the same electric parts for all its vehicles. I compared the Plymouth contact plates, identical!, slap them right in my JGC. They were small enough to pocket. Hey I’m not telling you what to do, but you got to find motivator.
This is my second Jeep, my first baby was a 1987 Jeep Pioneer, got me through Junior College and University, very fun times. I had the same identical issue with blown head gasket. So when I saw 93 JGC, I recognized the mechanical issues, I didn’t even sweat the chicken living in the Jeep. My brother has a 2000 JGC he still owes 10G on it, he was T off, my JGC ran as strong as his, its just a later model.
Anyways, Just wanted to share what I’ve been through. Hang in there.
Oh! I’m not dissing, but s10 blazer suck & swallow.
Peace n da middle East,
laloquera :runaround: :runaround: :runaround:
