Replaced Fuel pump ..Now no start
Emmitt101
09-26-2008, 09:24 PM
Replaced fuel pump last weekend and 96 LT fired up after a bit and was able to drive it until today. Went out for work this morning and it was cranking but would not start. Was running fine when I parked it yesterday. Is getting plenty fuel. Has rained here for two days now. Anybody think I may have a moisture problem somewhere or is it only a coincidence? Had no trouble at all with it until the rain. Is parked facing uphill, may have something to do with it?
MT-2500
09-27-2008, 10:28 AM
What engine?
Can you hear fuel pump prime up?
You need to verify good fuel pressure.
Does it have good hot blue spark to all plugs?
What brand of fuel pump did you use?
On fuel pressure you need more then plenty of fuel.
You need good volume and 65 lbs of fuel pressure on a cold start.
You can not leave home without it.
If a 4.3 engine
The only true test on a fuel pump is to check the direct fuel pressure from fuel pump.
A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs.
But do not run the pump at full pressure very long.
Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes
until the pump gets has run a while to check for a pump fading out after hot.
Hard to start cold or hot and fuel pressure testing guide lines.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak in system.
Post back fuel pressure readings.
