Exhaust Manifoldtomkinsa 09-25-2008, 10:11 AM The donut where the manifold connects with the y-pipe is bad. I can move the y-pipe up and down. Would this cause a noise at idle.It almost sounds like a ticking. ZL1power69 09-28-2008, 10:59 PM Yes, a bad donut will cause an exhaust leak. You may not hear the leak at idle, but under load, it will sound just like a ticking. I recently changed my y-pipe and have encountered the same issue. If the y-pipe is not lined up perfictly, the gaskets will not seal. The gaskets are basically a metal donut and are about $10 a piece. tomkinsa 09-29-2008, 09:48 AM Actually its only at idle that i hear the noise. Automotive Network, Inc., Copyright ©2012
