Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Pick-Up
Old 09-23-2008, 01:42 PM   #1
idayoda
idayoda Normal reputation
89 PickUp-22RE 4x4 5 spd(gas gauge/ac Stoped working)
The other day, the Gas gauge and Heater/AC controlls stopped. Checked the fuses in the cab and under the hood(all good). Also, the check engin light will not come on during start ups. The temp. gauge and Spedometer still work fine. Any Ideas would be a huge help.
idayoda is offline   Reply With Quote
Old 09-23-2008, 03:51 PM   #2
fourwd1
AF -Advisor
fourwd1's Avatar
fourwd1 Normal reputation
Re: 89 PickUp-22RE 4x4 5 spd(gas gauge/ac Stoped working)
First check the electrical connections and ground wires of the inst panel (back of the gauge cluster).
The Heat and A/C have a fuseable link in common, but I don't see any tie-in to the gas gauge. It could be 2 different problems.
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
fourwd1 is offline   Reply With Quote
Old 09-23-2008, 07:28 PM   #3
idayoda
That would be a big coincidence it they werent linked somhow right. I have had this truck for 7 years and have replaced most everything on it(mechanically), but never had two things go wrong like this at once, and I'm definitely less experienced with the electrical stuff. Thanks for the advice, you seem to be the go to guy on these threads. I appreciate it! So, is there any easy way to get to the inst. cluster you speak of?
Old 09-24-2008, 08:17 AM   #4
fourwd1
AF -Advisor
fourwd1's Avatar
There's 4-6 screws that hold the trim on, then another 4-6 screws that hold the cluster in. Then you can pull the cluster out enough to reach behind and disconnect the speedo cable (squeeze 2 tabs together). Then cluster comes out farther so you can get to the cables.
89 4Runner - stock
Old 09-24-2008, 02:25 PM   #5
idayoda
Thanks, Probably wont get to it till the weekend, but Ill let you know how it goes.
Old 09-25-2008, 04:34 PM   #6
idayoda
Starting ripping it apart today and found the fuse that burned out. there was actually one more fuse back behind an extended fuse in the box that I never knew existed because of the longer fuse. Replaced the fuse and now both the Heater and Gas gauge work. thanks for your help!
Old 09-25-2008, 08:47 PM   #7
fourwd1
AF -Advisor
fourwd1's Avatar
Great it worked out for you.
89 4Runner - stock
Bookmarks
Google
Web AF
