the fan in this sentra does not work like it should with the fan switch. it is wired to the ignition switch, so it turns on automaticly and stays on when the car is turned on. it is rigged like this so the car wont overheat. could someone give me any info on how to fix this problem. i would realy appreciate it thank you......
If there is power to the fan and there is a good ground the fan should work. If it doesn't the fan itself is bad. Most likely it is worn out from being on all the time. If it is the fan and you do end up replacing it it might be worth digging into the reason it does not work as the factory intended!
i apologize for the confusing question. the fan works good, it just doesnt work like it soposed to. the fan is rigged to the ignition, so it turns on and stays on all the time. it should work off a switch or something right.
yeah it should work off of the coolant temp sensor, and a relay.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
I think the best thing you could do is get yourself a cooling fan wiring diagram for this car. I want to say off the top of my head that there is a coolant switch that controls the fan on these but without the diagram I couldn't say for sure.
