Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 09-22-2008, 10:35 PM   #1
articmaverick
articmaverick Normal reputation
Unhappy Fuel leaking out of tailpipe
1997 3.3L Dodge Caravan. Fuel is leaking out of the tailpipe and smoking. Oil is not milky. Changed plugs, made no difference. Check Engine Light is on but can't get it any place to get codes. Anyone have any ideas what could be the problem?
articmaverick is offline   Reply With Quote
Old 09-23-2008, 12:36 AM   #2
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
Re: Fuel leaking out of tailpipe
Are you sure its fuel?
How does it run?
Airjer_ is offline   Reply With Quote
Old 09-23-2008, 09:26 AM   #3
MagicRat
The golden age
MagicRat's Avatar
MagicRat +50
Liquid fuel never leaks out the tailpipe when the engine is running. Excess fuel would be burned up in the catylitic converter.
It is normal for water vapor to come out the pipe looking like 'smoke' upon initial start up. Also, if the exhaust is cool, the vapor condenses and drips out the pipe.
If it's doing this very badly, engine coolant may be getting in the xhaust through a cracked head or blown head gasket.
"We' re all here because we're not quite all there."
I still say a church steeple with a lightning rod on top shows a lack of confidence
MagicRat is offline   Reply With Quote
Old 09-24-2008, 01:14 AM   #4
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
You can do the key dance to read the code turning on the CEL. Cycle the key from off to on (not start) 3 times leaving it on. Count the number of times the CEL light blinks. These blinks are the code. All codes have two digits. Each digit is separated by a pause. Multiple codes are separated by a longer pause. Code 21 would be blink, blink, pause, blink. Should finish with a code 55. Come back here with the results.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is offline   Reply With Quote
Old 09-30-2008, 09:36 PM   #5
articmaverick
It was fuel coming out the tailpipe, it's on everything that was behind it and on ground. One of the front injectors was stuck open. Got 6 for $75 from boneyard. Replaced the front 3 and problem resolved. Service Engine Light reset itself after driving a 1/4 mile. Thanks everyone for all the replies.
Old 10-01-2008, 12:27 AM   #6
RIP
AF -Advisor
RIP's Avatar
Guess we all learned something. Never heard of raw gas out the TP. Glad to hear you got it fixed.
Old 10-01-2008, 12:35 AM   #7
Airjer_
Airjer_'s Avatar
I haven't run into that yet myself. If one thing is for sure, ANYTHING is possible!!!
Bookmarks
Google
Web AF
