Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nova
Old 09-22-2008, 09:11 PM   #1
SuperNova76
SuperNova76 Normal reputation
Gas Mileage 305
Whats the average gas mileage for a 305 v8 smallblock?
There is something VERY wrong with my nova, Its only getting....Dare i even say it....4-5 mpg, and thats AFTER getting it adjusted from running to rich.
Any thoughts?
SuperNova76 is offline   Reply With Quote
Old 09-23-2008, 09:32 AM   #2
MrPbody
AF -Advisor
MrPbody Normal reputation
Re: Gas Mileage 305
A bunch of things are out of wack. That's deplorable fuel consumption.
Check cam and ignition timing. Is it a 2-bbl. or 4-bbl.? What is the rear axle ratio? Stock engine, or modified for performance? Please gve as much detail as possible.
Jim
MrPbody is offline   Reply With Quote
Old 09-23-2008, 09:32 PM   #3
SuperNova76
Re: Gas Mileage 305
1976 Chevy Nova Sedan
250,000 Miles ( estamated, the speedo only goes till 99,999)
305 SB V8
THM350 auto tranny
2 barrel carb
Everything is original, no performance parts, However parts have been replaced, as they do wear out but everything was OEM.
Not sure what that gear ratio is, I would go out and find out but I do live in the Not so great northwest and its been pretty wet out and i dont have a garage.
I have noticed it smells heavily of gas, but the air/ fuel mixture is correct, also there is this one random tube hanging off of the left side of the carb and its not attached to anything...It doesnt leak or anything like that.
The previous owner noted the car only got about 8-10 mpg at best.
The timing is a little off, it does grumble when I shut it off, sometimes more than other times.
Old 09-24-2008, 12:14 AM   #4
gatoratoy227
gatoratoy227 Normal reputation
Re: Gas Mileage 305
between 8-13 mpgs
NO! ,we can't stop here, this is bat country. Raoul Duke
gatoratoy227 is offline   Reply With Quote
Old 09-24-2008, 12:36 AM   #5
Scrapper
Scrapper Normal reputation
Re: Gas Mileage 305
those were prety good moters in the pontiac. my dad loved his and they do have quite abit get up and go his had a 4bcarb and not bad gas milage.
Scrapper is offline   Reply With Quote
Old 09-24-2008, 09:37 AM   #6
MrPbody
AF -Advisor
Re: Gas Mileage 305
Pontiac? Huh?
The "heavy smell of gas" is a key piece of information. How are you determining the air/fuel ratio is "good"? Was it "sniffed" on a scope or exhaust gas analyzer? Simpy setting the idle misture screws won't make it "right".
The gas smell could come from the charcoal canister being saturated, but that doesn't usually cause bad mileage. If the carb is flooding or leaking, THAT will. If the fuel pump is leaking, that too, will cause it. Smell your oil to see if there's fuel in it.
Keep the details coming...
Jim
Old 10-13-2008, 07:33 AM   #7
bobss396
bobss396's Avatar
bobss396 Normal reputation
Send a message via AIM to bobss396
Re: Gas Mileage 305
With the right rear, you should be getting at least 16 out of it. Get your fuel system sorted out, look for a bad section of steel fuel line and make sure that your rubber connections are good as well.
Bob
bobss396 is offline   Reply With Quote
Old 11-24-2008, 06:39 PM   #8
SuperNova76
Re: Gas Mileage 305
Sorry For the absence, I have been very busy with two jobs.
Now that i have a few weeks before I get busy again i decided to get back to work on the nova!
So after a long sit, I had the carb completely rebuilt.....HOWEVER! After reinstalling I try to start it and after a few seconds of running i smelled gas very heavily and turned it off and looked and there was gas all over the intake manifold....WHY?
I have everything tightened up real good and everything is connected..I also notived the new seals were completely soaked in gas (paper cardboard stuff) on the carb.
Old 11-27-2008, 08:59 AM   #9
j cAT
j cAT Normal reputation
Re: Gas Mileage 305
being a 1976 I not sure its been a long time ...did you check out your fuel cannister and the controlling valves...these valves have diaprhams...if they split it can cause low mileage and gas leakages..in the engine compartment..
the problem on starting the rebuilt carb may be the fuel line/gaskets...these parts have to be handled carefully and the gaskets replaced...
j cAT is offline   Reply With Quote
Old 12-02-2008, 12:37 PM   #10
bobss396
bobss396's Avatar
Re: Gas Mileage 305
Sounds like a hung up float. You can try rapping on top of the carb with a screwdriver handle a few times, but the float might not be hung right inside. Did the carb have a guarantee with it?
Old 12-02-2008, 07:59 PM   #11
SuperNova76
Re: Gas Mileage 305
Well After further inspection I discovered that while i watched it run, gas was spilling over the top of the carb and all down the sides and onto the engine, The guy who rebuilt my carb told me when he fixed it the diaphram had been destroyed,probably caused by back firing up through it, so i am guessing this is the case again....no there wasnt a guarantee or anything like that.
Bookmarks
Google
Web AF
