99 jimmy wineing noisetheyard 09-22-2008, 02:55 PM I have a 99 gmc jimmy 4X4 it started to make a wineing noise about three weeks ago I sounds like its coming from the front end i checked the the wheel bearings there is no play and I rotated the tires still have the noise check trans fluid and trans shift fine any help low on funds cant take to repair shop thank you john MT-2500 09-22-2008, 04:10 PM Does the noise change with MPH or engine rpm? theyard 09-23-2008, 10:37 AM It seems to gets louder the faster you go Airjer_ 09-23-2008, 10:39 AM Did you check the front diff fluid? jdmccright 09-23-2008, 11:44 AM Is it louder when you turn the steering wheel? If so, your power steering pump could be low on fluid. MT-2500 09-23-2008, 12:44 PM Wheel speed related. Going at steady speed 35-46 MPH down the raod turn you steering a little left or right. If noise changes when turn wheel a little. Check you front wheel bearings. theyard 09-23-2008, 07:29 PM ok I checked front diff fluid it was full does not seem to change when turning wheel had taken tires off there is no play in wheel bearings MT-2500 09-24-2008, 09:40 AM ok I checked front diff fluid it was full does not seem to change when turning wheel had taken tires off there is no play in wheel bearings Spin wheels with front end raised up and listen for wheel bearing noise. How is the tire thread? Some tires have more road noise than others. Good Luck theyard 09-24-2008, 11:27 AM I did check the for noise when I rotated the tires every thing was good mybe it is tire noise it just didnt hear it before three weeks ago Automotive Network, Inc., Copyright ©2012
