Re: flucuating fuel mileage
How old is the car?
As mentioned above, check for leaks. Vacuum leaks are not always obvious and they can decrease performance significantly. Also make sure tires are inflated to proper level, air filter is not plugged, and spark plugs and wires are good. If it has been awhile since you have done a full tune up, give the car some TLC and see if any of it straightens out the mileage problem.
More serious issues could involve a bat cat converter, but I would think you would notice more driveability issues wth a problem like that. It sounds as if the car drives normally, nut isn't getting the mileage you want?
Do you get your gas at a reliable place?
