distributor help
luxeryvic
09-20-2008, 07:27 AM
ok, i have an hei distrinbutor,onthe 305 in my 77 monte carlo, there is 4 prongson the side of the housing, 2 of themare connected by wires coming from the inside of distributor, where do the other 2 prongs get connected to, there is nothin in the wiring harness that i can find?
thanks
j cAT
10-03-2008, 08:07 PM
thanks
I believe one is the tach and the other is battery voltage...
luxeryvic
10-04-2008, 08:58 AM
ok i thought i read somethin like that, but my car doesnt have either gage so do i just leave them?
777stickman
10-04-2008, 10:48 AM
The terminal marked "BATT" requires 12v from the Ign sw in "start & run". Do not hook up a constant 12v batty source. "Tach" is only used if you have one, otherwise leave it empty.
j cAT
10-04-2008, 11:12 AM
yes just leave them as is...these are used to diagnose the distributor...If you wish you can hook up a tach to the tach terminal ..I did this with an older vehicle I once owned...
luxeryvic
10-04-2008, 10:36 PM
ok there is a thicker about 3/16 thick red wire that im not sure where it goes or a thin 1/16 or an 1/8 thick green wire which one goes to the distributor im pretty sure it the red one sorry the wiring diagram i have isnt very good
luxeryvic
10-04-2008, 10:42 PM
is there
luxeryvic
10-04-2008, 10:43 PM
is there a good wiring diagram online?
777stickman
10-04-2008, 11:13 PM
The red wire is the one that goes to the "batt" terminal on the dist as long as it has voltage in the "start & run" position from the ign sw. This wire powers the HEI. If this wire is not hooked up you get no spark from the dist.
luxeryvic
10-05-2008, 09:27 AM
wow you must really know your stuff, will i be lucky enough for you to know which plug on the disrtributor it plugs into?
777stickman
10-05-2008, 11:39 AM
Look on the top of the tab were the wires plug into for the words "BATT" & "TACH" embossed in the plastic. This tab should be facing the drivers side and the "BATT" terminal will be closest to the firewall.
16foxracing16
10-13-2008, 09:39 PM
777 is right..you have to have the BATT 12v source with switch on for it to get any spark. it controls the HEI
