Does my 88 Accord have wrong oil in manual transmission?dderolph 09-19-2008, 02:50 PM Earlier today, I had the left front half axle and front brake rotors and pads replaced by a small independent local mechanic shop. I don't know why, but most of the transmission fluid leaked out when the mechanic pulled the old half axle off. After replacing the half axle and brake parts, he added 80W-90 gear oil to the transmission. I don't have the owner's manual for this car, but I have a manual for a 91 Accord and it specifies 10W-30 or 10W-40 for the manual tran. I suspect the recommended oil for the '88 may be the same as for the '91. I don't want to leave the 80W-90 gear oil in it if it is the wrong oil. If someone reading this has a manual for '88 Accords, can you confirm for me what the manual recommends for manual transmissions in '88 Accords? mdhbhouse 09-21-2008, 03:57 PM I believe you are right. My '1987 Accord' manual tells me use the proper viscosity for the climate you live in and the chart beside it lists 10W-30, 10W-40 along with 20W-40 and 30. I'm looking at my automatic transmission problems right now and I'm sure I've seen posts saying just straight motor oil for manual trannys. dderolph 09-23-2008, 12:53 PM OK, thanks for that info, mdhbhouse. I think I'm going to call the technician and tell him he put the wrong oil in the transmission. Automotive Network, Inc., Copyright ©2012
