Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 09-19-2008, 12:08 AM   #1
donmaleta
donmaleta Normal reputation
Scanner does not link with ECU,Caravan 96'...
Good Day to All:
I'm having trouble with my 96' 3.0L, its kind of crazy its intermittent and while driving the engines surges one or twice and then dies... when I try to crank it up again cranks but don't starts if I try again it wont even crank ( no starter winding up ) what I noticed is that is I'm driving when it dies my check engine light disapears for a while and if I connect my OBD 2 reader does not link up with the ECU if I wait a while and I crank it up again its satrts and the while cranking up I can hear a bang noise from the engine compartment drives side and then after a couple of minutes dies again...
I'm really shooting blanks with this one !!!
Any input would be very appreciated...
Thanks.
Last edited by donmaleta; 09-19-2008 at 12:10 AM. Reason: Tittle not clear enough...
donmaleta is offline   Reply With Quote
Old 09-19-2008, 02:01 AM   #2
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Re: Scanner does not link with ECU,Caravan 96'...
Head over to Autozone for a free code scan. That will tell you if your scanner or the van is the problem and maybe what is creating the stall.
Have you tried the bash the dash trick? Might have a solder joint issue in the instrument cluster.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is online now   Reply With Quote
Old 09-20-2008, 01:23 AM   #3
donmaleta
Thanks for such quick reply...
Its funny because as soon the check engine light is online again my OBD reader work fine again its when it dies that the ECU & OBD scanner cycle is not available....... ?????
Thres this razy neighbor that sugested replacing the fuel filter and told me that that particular model has like an engine oil sensor that when it goes bad it cuts the ECU to avoid engine damage.... for me that sounds like the oil sensor the portable power generators have, but really for me dont make sense.
Thanks Again !!!
Bookmarks
Google
Web AF
