Re: 95 Escort Rear Window Defroster Switch
I had the same problem on my 92 Escort wagon. None of the auto parts places had the switch, nor did the Ford dealers where I asked. I found the few of them that were still in the salvage yards were like mine and yours - already busted. So if you find a source for that switch, let the rest of us know.
To solve my own problem, I got a 12 volt relay, & two momentary 'button' switches from ebay, and spent most of an afternoon making up a replacement setup. I used the original niche in the dash, with the relay stuffed behind the dashboard front. It worked fine; would either keep the glass heater on till I turned it off, or until I turned the ignition off.
Since then I have bought another Escort, a 94 wagon, whose defrost switch still works.
I have two Escorts because they get good gas mileage and are easy to fix.
