I need help in opening wheel covers. I have to know the procedure of taking off these covers.
I can see 5 or 6 'L' shaped clips touching the
wheel. They come out but the four nuts attached to covers are unable to open.
I can also see small rings with a little gap between their ends attached to the
these cover nuts. Do we need them to pry out ?
I would really appreciate if anyone could help me out in opening these covers.
Thanks
The hubcaps are held on by the black rings on the lugnuts. You will have to remove the lugnuts in order to take the wheel cover off. No way around it, unless you want to break it off.
John Nance, Parts Manager
Bob Rohrman's Indy Hyundai, Suzuki Superstore
7101 East Washington Street
Indianapolis, IN 46219 inss.partsmgr@rohrman.com
1-800-592-5170
317-613-7048
Once you take the lugnuts off you'll see how it all works. If I remember right the black rings are attached to the lugnuts themselves, and aren't that hard to get off if you want them off.
2005 Tiburon SE 2.7L V6 6sp manual
2008 Santa Fe Limited AWD, 3rd row, Nav
Thanks for your response. The rings are very small. Is there any way / tool to remove the black rings ?
Thanks once again.
You will have to remove the lugnut in order to remove the black ring, it's not hard. However, if you take the black ring off, there won't be anything holding the hubcap on.
1-800-592-5170
317-613-7048
