90 not startingaclafontaine 09-14-2008, 03:26 PM i have a 90 buick riviera and it doesnt start. i have checked the pass system and it doesnt eem to b causing the problem. fuel pressure is good. i removed one of the spark plugs ad tried to start the vehicle to make sure it had spark but nothing. any ideas why i wouldnt be getting any spark? the vehicle was being driven when it just died. i assume it died due to lack of spark. any ideas would be great. maxwedge 09-14-2008, 03:28 PM Welcome to AF, no spark and no injector pulse can be caused by either the ign control module under the coils or more likely the crank sensor, access to a scanner will allow you to check for cranking rpms, also check the wiring from the cps to the icm. Scrapper 09-14-2008, 06:44 PM have you checked see if you got spark on the coils or coil pack i no you said you pulled plug out. now if your getting spark on all plugs? i would go for the module. and like mod says could be you cps. HighMileage230000 09-18-2008, 04:31 PM The same thing happened to me and it was the Crankshaft Position Sensor. I found this out after replacing coil packs, ignition module, and camshaft position sensor.:banghead: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
