08 Caravan adjusting power doorpokerman11 09-14-2008, 11:31 AM My local dealer went out of business so taking this into the shop is not an easy option. The passenger side power sliding door - shuts but then sometimes opens back up, as if the door was blocked. It does this about 1/2 the time. I see a little cable in there, not sure it the cable should be in the track or around it. The track is clean. I was thinking of trying some silicone based lube. Any suggestions on adjusting the door? tks Robertmchenry 09-15-2008, 08:22 AM My local dealer went out of business so taking this into the shop is not an easy option. The passenger side power sliding door - shuts but then sometimes opens back up, as if the door was blocked. It does this about 1/2 the time. I see a little cable in there, not sure it the cable should be in the track or around it. The track is clean. I was thinking of trying some silicone based lube. Any suggestions on adjusting the door? tks I would assume an 08 would still be under warranty. I strongly suggest you take it in to the dealer and while your at it ask them how much oil the engine takes. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
