Starter about to Die? -- 97 Gr Crvn
Google
Web AF
stb100
09-10-2008, 10:02 AM
When I try to start the van, sometimes it fires right up strong. Others, it takes 2 or 3 tries and does different stuff when i turn key: motor turns slow...or there's a click and a groan...or nothing at all.
Has brand new battery--thought that was the problem.
It's a '97 ES w/ 3.8 L
So, any sure bets on cause? If starter, how tough is that to replace?
THANKS
Steve
Mbriggs
09-10-2008, 01:18 PM
My experience with starters (replaced 4 on caravans) is that it's either a click and nothing, or a normal start. A slow turnover might indicate something else. The telltale is when it gets bad enough, you have to whack the starter with something to get the car to start.
You can remove it and have it tested for free at Autozone or Advance, but access to the top bolt is tight. Remember to disconnect the battery first! I didn't the first time and got a good jolt!
angus10
09-10-2008, 01:34 PM
Check the connections first. Also check the connections at the alternator and the grounds on the motor.
Robertmchenry
09-11-2008, 04:52 PM
VERY EASY to replace the starter, Two wires & two bolts!
pokerman11
09-14-2008, 11:33 AM
Taking the starter off is one of the easiest tasks in automotive. Two bolts and two wires.
Often it is the connection, but they are so easy to take off. I would take it off and go down to autozone or a similer place. Most of these places have a testing machine that will test if your starter is good or bad.
Google
Web AF
