Car Wont Start Vats Wire Spark Help!!!!
igot95
09-08-2008, 08:20 PM
Man This Is The Worse Day Of My Life I Was Installing My Remote Starter So I Bypass The Vats System And It Worked Then I Acidetly Touched My 2 Ignition Wire On My Vats Wire Its Was A Couple Off Sparks Then I Tryed To Start My Car And The Pass Key Light Didnt Pop Up On Dash And The Car Didnt Start Plz Help Its A 1995 Caprice
j cAT
09-09-2008, 07:20 PM
start checking all fuses...use meter to be sure...
igot95
09-09-2008, 08:26 PM
ok i used a fuse thing to chech my pass fault fuse its like a yellow thing with 2 silver metal pices on it and a green light the green light came on for both should i us a volt meter this guy tht works at the alarm place said i should look at my ign fuse idk where it can some1 help
j cAT
09-10-2008, 10:16 AM
find someone with knowledge to help you with the checking of the fuses and methods to safely troubleshoot this....
igot95
09-10-2008, 09:22 PM
i jus got it towed to the dealer ship thy gave me an stament thy said drum roll a wooping 575
j cAT
09-11-2008, 08:50 PM
not now,, but after they have repaired your vehicle post back what was damaged and the final total cost.
igot95
09-23-2008, 11:54 PM
Well i got my car back and i guess i cut all my ground wires or somthing and the had to replace my vats wire and i new wiring harness somthin like that but the cost is 513.79
