Both front turn signals not working...?
Slim Jim
09-08-2008, 09:52 AM
I just purchased an '03. Both front turn signal lights are out; the previous owner said they'd burned out a few weeks prior, and seemed to think they didn't both blow at the same time. At $3.50/pr at autozone, I didn't make a fuss. But after I replaced both bulbs (they were indeed blown), the flasher still ran fast, and only the rear turn signals were blinking; nothing out of the fronts. I checked the bulbs, and they're still good.
FYI, no DRL; Autozone tried to sell me the wrong bulbs until I clarified that.
Any ideas on what's going on here?
4Wheel
09-08-2008, 02:33 PM
You may have bad contacts in the sockets.
You need a meter at this point or a tester light at minimum.
check the wires for voltage on the BACKSIDE of the socket, use a small sharp probe tip to puncture the insulation. If you have no voltage there then trace it back, this will require a schematic.
Rough Rydner
09-10-2008, 01:56 PM
I think you need to replace your flasher relays and check your fuses. Here's what I found for you. LINK Link removed by Moderator - spam
fourwd1
09-11-2008, 04:52 PM
If the rears are working, the flasher unit is good.
You need a DMM and a wiring diagram and start checking from the sockets on back. Also check the grounds.
