99' GCL center console lightsGoldfishy 09-06-2008, 09:14 PM In driving at night, the light(s) have gone dark, so that I can no longer see what drive gear I'm in, or need to take a guess. I'm assuming there's a bulb inside the console. I don't see the whereabouts to pull or take the console out and check for a burnt bulb, I already checked the fuse box and everything seemed okay. Bob D. 09-06-2008, 11:05 PM It's not a bulb, it's a non-serviceable luminescent light strip. The console shift assembly module needs to be replaced. Remove the center console then pull the shift assembly apart. You can check the strip and connectors - if you find a crack it may be repairable. Automotive Network, Inc., Copyright ©2012
