Have a '96 1500 5.9 4X4. Died on me a couple of months ago. The tranny relay and speed control servo clicks and it won't start. Have replaced the tranny relay, checked the PDC for burned wires. Have replaced the ignition coil, plugs, wires, dist. cap and rotor. Also replaced the camshaft and crankshaft position senso. Bought a new battery with high cranking amps and new clamps. Have cleaned the connections to the starter and the alternator. Looked for a diagram following the tranny relay. To no avail can't find one with enough detail. Have done more but would need my list. The fuel pump works sending fuel and pressure to the fuel rail. Ran the codes manually. Only got #12 stating that the battery has been disconnected within the last 50 cranks. Well, hello. It is getting better. Got it to start after replacing the plugs. Ran well enough that it would rock the truck. Then it died on my again and wouldn't start.
Has ran one other time. Died even sooner this time. Oh yeah, I have a half of tank of gas. Ever get another truck, IT WON'T BE A DODGE! Think we all need a class Keeping a Dodge Running 101.
