Re: Hold button and 4th gear Help Please.
Is the check engine light ON ?
NOrmally, when youturn the key to ON and start the engine, the HOLD light is OFF and in tht consition, car should start in 1st gear up to 4th...but in fact 4th engages just once engine temperature is above 140°F
If for some reason the thermostat is stuck open and engine cools down below that temp on the open road, it will revert to 3rd......or if some false temp indication is fed to the computer.
Start with those ideas and come back with findings.
I don't believe in miracles.
