1990 Vandura 5.7 vibrationaxekick 08-31-2008, 10:04 PM There is an annoying vibration at higher RPMs that persists even at a stand still in park or neutral. Is it likely to be caused by the torque converter? Any other suggestions or clues I should look for? maxwedge 09-01-2008, 04:00 PM Many things can cause this, a cracked flywheel is common, also remove the belt/s and see if it goes away, bad trans and motor mounts another possibility. axekick 09-01-2008, 05:39 PM Thanks for the reply. I'll check those things. Automotive Network, Inc., Copyright ©2012
