Re: Radiator leak
Have you been regularly checking the coolant level during the two weeks since it was changed or was this the first time since the change? The reason I ask is many times after changing coolant it can take several days for the level to stabilise due to air pockets throughout the system. The level you are seeing may be where it finally settled a couple days after the change. You may just need to add coolant.
If that's not the case then I would high tale it back to the rad shop and state your case. Yes, they should fix it under warranty. To check for leaks check the frame below the radiator and at the radiator hose connections for wetness. Look for any puddles/droplets on the pavement under the car while it's running and after it has sat off for a while. If you have to park on an unpaved spot, slide cardboard under the car to catch any liquids. Coolant can either be a light green/yellow or red/orange.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
