Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Corvette
Corvette
Old 08-28-2008, 06:57 AM   #1
porky2149
porky2149 Normal reputation
86 hard to start
my 86 when cold will start but the gas pedal must be pumped to keep it runni9ng .even then it is hard to keep running and will fire in the intake {backfire}.when the temp to about 135 it runs better and will level out at about 165. thanks
porky2149 is offline   Reply With Quote
Old 08-31-2008, 11:16 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: 86 hard to start
Any error codes/check engine light? If the engine does not idle, check for vacuum leaks and remove/check/clean the IAC (underside of the throttle body).
It might also be a good idea to clean the throttle body and air passages, and check the TPS voltage at the closed throttle position.
Once that is done, if conditions do not improve, check fuel pressure and injector leakage (fuel pressure drop at shutdown). Don't forget the cold start injector.
Blue Bowtie is offline   Reply With Quote
Bookmarks
Google
Web AF
