rear shocks
Question: While swapping old shocks for new I broke off the upper stud from the frame rail. Not the stud for the upper shock eyelet but the support plate. So right now the support plate is held in place by the upper shock stud and the bolt which is rearward from the broken stud. The support plate does not look like it has moved or twisted since I put it back together. That said, I looked inside the van for the backside of the stud in hopes that I can drive it out and install a new one. no such luck. The seatbelt bolt which is 2" away is the only fastener visible. The stud must be welded in place. Can this be fixed or does it matter? From the looks of it, it does not bear any load from the shock absorber.
