92 Supreme S 3.1 Front Squeak/CreakMikey_G 08-26-2008, 09:35 PM My 92 Supreme S 3.1 has a squeak/creak/rattle in the front right corner. Squeak: 1. Squeaks/Creaks/rattles even when car is off and I bounce it a little. 2. Squeaks/Creaks/rattles just after engine is turned off but before it totally stops turning. 3. My thoughts are that the problem is either the inner CV joint or the transmission. I hesitate to think it's the transmission because it makes the noise even when the car is off. 4. There is no popping noise whatsoever when I turn so that makes me doubt my diagnosis of a CV joint, however. Also, it still makes the noise even when the car is sitting still and off. Any ideas would be welcome. I am a relatively new weekend mechanic. Thanks much, Mike Mikey_G 08-27-2008, 10:55 PM OK -- Solved the problem. It was a small piece of the heat shield that was rubbing on the frame. Bent it back a little and no more noise. Problem was that the noise would occur when weight was placed on the vehicle. Didn't want to do that when I was under it. Automotive Network, Inc., Copyright ©2012
