venture 4t65egeovair66 08-26-2008, 07:17 PM hey all. can anyone tell me if the 4th gear clutch hub be removed from this tranny from the valve body side? i think mine is stripped at the splined end as i have no more 4th gear and have allready changed the pressure control solenoid and the tcc switch and the fluid was clean before replacement? and how tough is the job? i am mechanically inclined so ill be doing it myself. any help is appreciated in advance:evillol: merc81 08-27-2008, 08:08 AM So you would be planning to remove the valve body assembly to get at it then correct? I have a manual but its not here--I'll look it up tonight and post again tomorrow what I find on the location and how to change it. Taking the valve body off scares hell outta me, but then if the tranny isn't working what's to loose I guess :uhoh: Sturmvogel 09-05-2008, 12:41 AM have allready changed the pressure control solenoid and the tcc switch and the fluid was clean before replacement? geovair, Can you give me any pointers on changing the tc switch? Thanks in advance! -Kirk Automotive Network, Inc., Copyright ©2012
