Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 08-26-2008, 06:23 PM   #1
nonenino
nonenino Normal reputation
99 accord a/c problem
Hello gurus, my 99 accord's(4 cyl. 5 speed,200k) a/c panel lights come on and go off intermittently, when the panel lights are not on, the a/c doesn't work. There doesn't seem to be a pattern as it can happen at any time. All fuses are good. Do I suspect the compressor is going bad? (maybe the 200k miles on it?) I appreciate any input!
George
nonenino is offline   Reply With Quote
Old 08-26-2008, 08:28 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Re: 99 accord a/c problem
I would say it's more likely the panel control is failing...not uncommon in those old ones. They are pricey, if I remember right...try getting a salvage one to try if you can find one cheap...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 08-27-2008, 12:26 PM   #3
somick
somick's Avatar
somick Normal reputation
Compressor is driven by a belt. Could it be just a stretched belt...
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 08-27-2008, 03:50 PM   #4
nonenino
Thanks Jeff, I took the a/c control/ radio panel out and checked the connectors, but still not turning on. I found a 01 manual control panel, with the same knobs and buttons, just a slightly different design of the a/c control panel on the front( is not recessed like the 98-99)l but the back connectors seem to be the same( the round and green connectors). I'm hoping is all the same so I'm going to give it a shot. I'll keep you posted.
Thanks for your help
nonenino
Old 08-28-2008, 09:42 PM   #5
jeffcoslacker
Sam
Even if the belt slips, the compressor clutch is still engaged...the A/C control panel would not indicate it...
...empty gun rack.
Old 08-29-2008, 12:28 PM   #6
somick
somick's Avatar
I did not know that. On my Subaru they have a sensor that shuts down the compressor once it there is a belt slippage.
Sam
Old 08-29-2008, 09:08 PM   #7
jeffcoslacker
Sam
that may be...I'd think it was more likely the belt was slipping from overpressure, and the high pressure limit switch was cutting the compressor...but they have so many different safeties on cars now who knows?
...empty gun rack.
Bookmarks
Google
Web AF
