fornt end not rightradrodder04 08-23-2008, 01:47 PM the front end of my 95 camaro has vibreations dirves fine except for that my mechanic drove the car and said it needed a right front hub assembly. my question is why shouldn't I replace the wheel bearing ? muff34 08-24-2008, 12:07 AM bearing is part of hub assembly,cannot be done seperately radrodder04 08-24-2008, 02:16 AM well I obviously am surprised, you mean that if the wheel bearing goes out, the hub assembly has to be replaced. it can't be pressed out and a new one put in, or is replacing the assembly a better solution? By the way thanks for the prompt and very informative answer. Morley 08-24-2008, 02:48 AM well I obviously am surprised, you mean that if the wheel bearing goes out, the hub assembly has to be replaced. Correct. The hub is a sealed integral assembly. there is one on E bay now for $84 http://cgi.ebay.com/ebaymotors/99-00-01-02-Camaro-Front-Wheel-Hub-&-Bearing-*NEW_W0QQitemZ380056729706QQcmdZViewItemQQimsxZ200 80820?IMSfp=TL0808201727r31714 After that you are looking at around $135 from a parts store. Happily the 3rd gens still used the old spindles with bearings that just slip on and off.:grinyes: radrodder04 08-25-2008, 09:14 PM thanks for everything this laborday weekend I'm going to install the new hub I ordered thanks for the contact and new brakes all around... see ya Automotive Network, Inc., Copyright ©2012
