transmission goes to neutaln2racingcars 08-20-2008, 06:18 PM I have a 99 GTP. 129K going down the road the cars just lost all gears. I coasted to a stop and had nothing. I shut the car off and then started 1 minute later and it was ok. Went about a mile and it did the same thing. What can it be? BNaylor 08-20-2008, 07:24 PM What forward gear are you in when this occurs....1, 2, 3, or 4(OD)? If in 4th - OD this is one possible symptom of a bad 4th clutch shaft. Transmission will default to neutral. troy1 08-20-2008, 10:11 PM worst case, trans is shot and is plugging the filter. Does it start to whine when it stops? n2racingcars 08-21-2008, 09:59 AM It does it in any gear. There is a little whine right before it stops. Could this be that the filter or tube has come loose and after the fluid is sucked up it doesn' t have enough fluid to run the tranny? troy1 08-21-2008, 02:35 PM no the filter will not fall out of place with the pan on. I would pull the pan and see whats inside BNaylor 08-21-2008, 04:27 PM I would pull the pan and see whats inside :werd: Out of curiosity was a 50K or 100K mile transmission service consisting of screen filter and ATF ever performed on this autotransaxle? Automotive Network, Inc., Copyright ©2012
