problems with my 93 honda civic lxkmerc 08-20-2008, 09:51 AM i have a 1993 honda civic lx and when i make left or right turn i hear a knocking noise from the right tire , but i dont know if its the tire, wheel bearing, axle or suspension. what do you think it might be? StealthSnake36 08-21-2008, 05:20 PM lift the car up (safely) and turn the steering wheel to the right (position it similar to the way you would normally turn when the knocking occurs and see if anything hits the wheel lessthanwise 08-22-2008, 04:57 AM bad cv joint... kmerc 08-26-2008, 08:51 AM how much do you think it will cost to get fixed r1d3r08 09-12-2008, 01:17 AM It could be repaired...I once have this knocking noise in my honda civic LX95 and it cost me less than Php1,500 nothing is replaced... wreckchord 11-28-2008, 01:41 AM i have a 1993 honda civic lx and when i make left or right turn i hear a knocking noise from the right tire , but i dont know if its the tire, wheel bearing, axle or suspension. what do you think it might be? I would take it in. A few things it could be... BEARINGS, BALL JOINTS... improperly tightened lug nut(s) But for sure get it checked out, anything with front end suspension / steering, you should be very pro-active with. No need to have a front tire fall off when turning... (knock , knock sound is like a pop, pop sound of a ball joint popping out slightly and back in when under stress.. ) chisling67 04-21-2011, 12:26 PM That is true you can lift the car and rotate the wheel by your hand and check if still you can hear a noise or not. Automotive Network, Inc., Copyright ©2012
