Rough idle/stalls when put into gearsarge76 08-20-2008, 12:45 AM I have a 95 widstar 3.8 and i just replaced the head gaskets on it. Got it all back together and there is a rough idle and even worse when hot. Once it gets warm and you put it into gear it will die if you dont keep it running. I hear no vacuum leaks and it isnt throwing any codes. There is no back firing. Also, when i was driving it around, i would take off and the trans did not want to shift into second without feathering the accellerator. Ive disconnected the IAC and tried to put a vacuum on the EGR and it would die with just a little bit of vacuum. Im stumped and need some assistance. Also changed the MAF, EVR, and PCV valve.:mad::mad::mad::mad: Someone please bail me out. Robdaparamedic 08-27-2008, 11:04 AM Take this for what it's worth.. :icon16: I was trying to find a coolant leak after I took off the air filter tunnel and my van wouldn't run worth a damm. I could barely keep it running and had to jump on accelerator. Then it would just stall. Make sure you have all your electric sensors plugged in. Good Luck Rob Automotive Network, Inc., Copyright ©2012
