How do you make the signal lights blink faster?
HondaAccordV6
10-18-2001, 07:32 PM
need some info on how to make blinkers faster...thanks
kris
10-18-2001, 08:26 PM
Welcome to AF
Here is what you need to do. I dont know if the pics will look the same on a Accord, but they will be similar.
You need to remove the flasher relay. It should be similar to this:
http://jdmfan.com/technical/cosmetic/rapidflasher/flasher.jpg
Open up the flasher and look for this resistor:
http://jdmfan.com/technical/cosmetic/rapidflasher/resistor.jpg
You will need to change this resistor to make your signal blink faster, or slower. The resistance is around 90K If you want to make your signal blink twice as fast as stock, then you would replace the resistor with a 45K.
The lower the resistance, the faster it will blink.
nittanys1
11-07-2001, 08:10 PM
OR you could buy a replacment flasher relay off of ebay for $10-$30
But they have them for different years.
If your car is from 98-02 go here:
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1660539011
If you car is from 94-97 go here:
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1660539064
The auctions end in 3 days & 6 hours from now....8 pm on Wend. Nov. 7th
super 96 accord
11-07-2001, 08:41 PM
I have an adjustable one at home that's never been used if you want it for $15
blk_wdw@hotmail.com
It's real easy to install, you take out the existing flasher unit and replace it with this one. It has a knob attached so you can adjust the rate it flashes.
94civic
12-01-2001, 09:18 PM
or you can put the bulbs in the other way around but you will have to make notch inside the holder so it will go in.
green accord
11-19-2003, 04:37 AM
you can put in a leb bulb that will work too
green accord
11-19-2003, 04:38 AM
led
