Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 08-16-2008, 12:58 PM   #1
christypea
christypea Normal reputation
Angry 1998 Ford Contour SVT starting on its own!!!!!!!!!!
1998 FORD CONTOUR SVT - WELL ON WED AM MY HUSBAND WAS GOING TO WORK AND HE CAME BACK IN THE HOUSE AND SAID CHRISTY DID YOU GO SOMEWHERE LAST NIGHT, BECAUSE THE CAR IS IN FRONT OF MY TRUCK AND WAS IN THE FRONT OF THE HOUSE. WELL (NOW I AM FREAKING OUT) THE BATTERY WAS DEAD AND SO TO MAKE A LONG STORY SHORT, WE CHARGED THE BATTERY AND IT TRIED TO START CRANKING ON ITS OWN.. FREAKY HUH! SO ONE OF OUR BEST FRIENDS OWNS HIS OWN SHOP AND SO HE FIGURED IT WAS THE STARTER, BECAUSE IT WAS STARTING TO STICK. THOUGHT IT MIGHT HAVE BEEN THE RELA , BUT ITS NOT... SO WE TOWED IT TO HIS SHOP AND CHANGED OUT THE STARTER/CYLANOID <--THEY ARE ATTACHED. EVERYTHING WAS GREAT IT DROVE GREAT LAST NIGHT. MY HUSBAND WENT OUT TO GO AND GET COFFEE AND CHRISTINE WAS ALIVE AGAIN. THE CAR WAS IN FRONT OF HIS TRUCK AND NOW I HAVE A DENT IN MY WHEEL WELL. I PUT THE KEY IN IT AND THE BELL DINGS LIGHTS COME ON BUT WONT START. HOOKED UP BATTERY CHARGER STILL NO SPARK! HELP!!!!!!
christypea is offline   Reply With Quote
Old 08-16-2008, 05:05 PM   #2
rhandwor
rhandwor Normal reputation
Re: 1998 Ford Contour SVT starting on its own!!!!!!!!!!
Take a voltmeter and check the battery voltage. Have somebody check the voltage when trying to start. It should still be around 12 volt. Check if the small wire feeding power to the relay is getting power. I would start at the ignition switch and make sure its working if you don't get power on the small wire to the relay. This is on the column about 1/2 way down.
Is somebody playing a prank on you?
rhandwor is offline   Reply With Quote
Old 08-16-2008, 07:13 PM   #3
christypea
Smile Re: 1998 Ford Contour SVT starting on its own!!!!!!!!!!
Thats a good place to start, it seems like somebody is playing a prank, huh. Thank You. Will let you know
Old 08-17-2008, 04:14 PM   #4
beyondloadedSE
AF Ford Contour-Advisor
beyondloadedSE's Avatar
beyondloadedSE Normal reputation
A similiar thing happened to a friend of mine with a 2000 SVT. We were out crusing around one night and we revved at a GTO and all of the sudden while the car is running, the starter just starts cranking. We immediately shut off the car and the starter just keeps going. Within a couple of minutes the battery was completely drained. We initially thought the starter was bad so we replaced it. Didn't fix it. Turns out the main harness that connects the starter to the battery had cracked/chaffed and was shorting to the frame of the car. I think the harness was about $100 from the dealership.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
beyondloadedSE is offline   Reply With Quote
Bookmarks
Google
Web AF
