Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-15-2008, 09:58 PM   #1
groovyforster
groovyforster Normal reputation
94 camry 2.2 pcv removal
How do you change the pcv valve? I've been pulling & pulling on this thing but it doesn't want to loosen up.
groovyforster is offline   Reply With Quote
Old 08-16-2008, 07:03 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Re: 94 camry 2.2 pcv removal
After all this time, the rubber grommet holding the PCV valve in is likely old and hard. Gentle use of a prybar or screwdriver under the metal lip should ease it out. The real trick is getting the new one in. If you can, ask the parts store guy if he has a new PCV grommet as well. If not, coat the PCV end with some oil and push it in as far as you can, then use a screwdriver tip and a soft-head hammer to tap it home...putting the tip on the metal part and working around the valve.
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 08-16-2008, 10:14 PM   #3
groovyforster
That worked. Thanks for the help!
Old 08-19-2008, 04:13 PM   #4
Daniel M. Dreifus
AF -Advisor
Daniel M. Dreifus Normal reputation
If you ever replace the PCV grommet, I've found it is best to do this with the valve cover removed as then you can invert it so broken pieces of grommet don't fall inside.
Daniel M. Dreifus is offline   Reply With Quote
Bookmarks
Google
Web AF
