2002 venture head how to?Andrewhuffman 08-14-2008, 12:26 AM what are the possibe side effects of a LIG gone bad? my problem is i have a cylinder pumping air into my coolant system. i removed the spark plug and watched tons of water pump/shoot out. assuming this is a gead gasket problem eventhough there is no water in my oil, and no white exhaust smoke, how would i go about fixing this? can the gaskets be replaced with the motor in? where can i find a "HowTo" should i just swap the motor with a junkyard motor? could this not be a HG and juat a LIG? what parts will i need to fix this on a budget? Nitro23 08-14-2008, 09:46 AM It's pretty straight forward and can be done in the vehicle. Search the threads there are some very good write-ups. From your description you definitely have a bad head and head gasket. Heads are expensive. If your motor is not knocking, I would replace the heads, head gasket and LIMG. You have to replace the LIMG when doing the heads anyway. Andrewhuffman 08-14-2008, 12:19 PM the vehicle has 150K+, but he bottom rnd is solid, it was a service vehicle, for mail delivery. so when i got it it still had the new car smell and was very well maintained. not mch has changed to it. so i think its worth fixing.100$ isnt bad. just need to know where to find them. inafogg 08-14-2008, 01:05 PM you definitly have a blown head/gasket if its pumping coolant out spark plug Andrewhuffman 08-15-2008, 12:14 PM where are the "How To"s? any advice umpon this task, where do i start, what can i leave on? inafogg 08-15-2008, 01:26 PM autozone.com Cressidaadr 08-16-2008, 09:55 AM where are the "How To"s? any advice umpon this task, where do i start, what can i leave on? I have seen some partial threads on how to replace the headgaskets so you may want to continue searching the threads. How about writing up a summary as you do your heads as it would be nice to have more information in one place? Automotive Network, Inc., Copyright ©2012
