Re: 90 swap to 91 cluster,tach will not work
Assuming the new cluster is good, more than likely your wiring harness doesn't have the wire for the tach (esp since it's a 22R, and RE would need that signal).
You can run a wire from the connector on the coil up to the cluster. A Factory Service Manual will have a pin out diagram of the connector on the cluster.
If you didn't get the oil press sending unit along with the cluster, that would be why the gauge isn't working. The idiot light sender will not work with the gauge. There's a possibility it may have also damaged the gauge.
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
