clear over pin stripe tape?.regg187 08-12-2008, 11:34 PM Is it OK to apply clear coat over pin stripe tape, or should I just pull it and reapply when the clear is cured. This isn't a show vehicle, just a basic new color job. It is a single stage paint ,I applied the tape already and now they want it clear coated . thanks in advance Regg dope92cc 08-14-2008, 02:43 AM no no no only have paint under the clear coat. someday you or the next owner will want them off. summer09 08-14-2008, 03:00 AM certainly not! unless you want a dirty paint job on your ride... BoricuaPaintFan23 11-23-2009, 05:25 PM Is it OK to apply clear coat over pin stripe tape, or should I just pull it and reapply when the clear is cured. This isn't a show vehicle, just a basic new color job. It is a single stage paint ,I applied the tape already and now they want it clear coated . thanks in advance Regg Regg>The customer is always right except when they're wrong. Pinstripes can be applied under clearcoat without issue and can help to prevent a pinstripe from fading because of the UV screeners that are incorporated into most clearcoats. Additionally, the clearcoat can be a physical barrier as well that can prevent physical damage being done to the pinstripe. Throwing things yelling in a mad high pitch. Here we go again with this psycopath #####.:nono: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
