Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 08-12-2008, 08:59 PM   #1
nvious62
nvious62 Normal reputation
89 accord wont start
have a 89 accord that wont start. it is fi has 300,000 miles on it. It is getting spark. fuel pump is running. the only time it will start is if you spray some starter fluid in it and then it will run till burns that off and then cuts off any ideas where to start troubleshooting and what all to check for any help is appreciated.
nvious62 is offline   Reply With Quote
Old 08-12-2008, 09:12 PM   #2
corem
corem Normal reputation
Send a message via MSN to corem Send a message via Yahoo to corem
Re: 89 accord wont start
Start with fuel pressure! If you here the pump running that doesn't mean that the pressure and volume are right. If those are good then check compression may be to low to let engine biuld compression. But very unlikely.
Hope this helps you out !!!
corem is offline   Reply With Quote
Old 08-13-2008, 08:30 AM   #3
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Yeah you need a minimum fuel pressure to open the injectors...I don't know the spec offhand but most need in the neighborhood of 35 psi at the rail...
Check the fuse and grounds for the injectors also...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Bookmarks
Google
Web AF
