>>Vacuum hose problem???TCHRISD 08-12-2008, 04:40 PM I have a '01 1.6L accent. The service engine light recently came on and when I went to Autozone to get the codes read the guy said it is showing fat and said there is a leak in one of the vacuum hoses? Question: How do I locate the leak and is it hard to replace a vacuum hose? jd-autotech 08-12-2008, 04:51 PM no hoses are easy to change but if you could tell us what the code number is it would help us help you TCHRISD 08-23-2008, 09:41 AM no hoses are easy to change but if you could tell us what the code number is it would help us help you the code is: P0442 Scrapper 08-23-2008, 09:47 AM take carb cleaner and every vaccum hose you see spray on them if it idles up there your leak... TCHRISD 08-26-2008, 03:57 PM take carb cleaner and every vaccum hose you see spray on them if it idles up there your leak... Would starter fluid spray work just as good? Scrapper 08-26-2008, 10:35 PM no no no you'll get hurt that way could also kill you.just use carb cleaner. TCHRISD 02-04-2009, 02:04 PM Hey guys. I still have this code on my car. I bought a new gas cap with no results. I got some carb cleaner and sprayed every place I saw a hose with no reaction. Can someone give me another thing to look for ? vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
