tranny flush gone wronggoongrinch 08-11-2008, 09:23 PM did a trans flush on a 03 dodge dakota the other day and today it came back with the engine light on and a tranny code po700 tranny malfunction....never had this happen to me before.. it shifts fine, but the code will pop up right away after clearing it so its a hard code..... dunno what to tell the big boss when he comes back.. help fluid level good,flushed with dexron 3.... no filter change..... spytearbite 08-14-2008, 10:55 AM If the car is still drive-able, take it for a ride. Then pull the Trans dipstick as it is running. See if there are bubbles on the stick along with the oil. Say the used filter is sucking in air and those are the bubbles on the stick is also the code. Sorry, do not know the product or have the factory service manual to know that code display. Find the obvious first is you last repair and that is what set the code was the fluid change or say the filter dropped out you dropping the pan? :confused: J-Ri 08-14-2008, 04:56 PM fluid level good,flushed with dexron 3.... I believe that vehicle should use ATF+3 or ATF+4, NOT Dexron 3... it should say on the dipstick, in the owners manual, in the service manual, and probably in the documentation that came with the machine. partsmgn 09-01-2008, 09:12 PM Most likely it's the combination of the imprope fluid and maybe because of hte fact that the filter wasn't changed take it back to the place it was done and raise hell with them perhaps they damaged a wire on the sensor in the tranny goongrinch 09-01-2008, 11:54 PM i worked on the car, we have this trans machine that claims u can get 99.9 percent of the fluid out without changing the filter....supposivily it cleans the filter out which i do not believe at all. maybe a metal filter in a honda but not for the big 3. but i used some universal fluid that is suppose to work for any tranny past 1983...its made by pennzoil...yeah i just work for a huge auto chain and go by what they tell us to use and do. luckly the customer hasnt came back...yet. partsmgn 09-02-2008, 12:02 AM Which auto chain do you work for? partsmgn 09-02-2008, 12:04 AM Most likely you would have to change the filter... in my store the mechanic always change the filter with every tranny flush.... for a 174.99 it better be changed!!! goongrinch 09-02-2008, 12:48 AM brakemasters... i worked for firestone and we did filter every flush..brakemasters does things differently in so many ways. partsmgn 09-02-2008, 12:53 AM I don't know if the incorrect fluid would cause the tranny light to come on though.... the only way I can see it coming on is by decresed flow of fluid past the sensor..... could also be lack of oil pressure in the system also..... goongrinch 09-02-2008, 09:58 PM this isnt the first time we had a problem car after a trans flush,we have had 2 come back on a tow truck before,one because it wouldnt go into reverse once the cutomer got home.... the filter was clogged with gunk...... the other was a tranny flushed with radiator sealent......tech was fired for that one haha. Automotive Network, Inc., Copyright ©2012
