Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 08-11-2008, 11:33 AM   #1
Mr.gangle
Mr.gangle Normal reputation
Front brake pads
2002 malibu, I am installing front brake pads on my car and found the inside pad to be much more worn than the outside pad on both wheels. Is this normal or do I need to look for more trouble?
Mr.gangle
Mr.gangle is offline   Reply With Quote
Old 08-11-2008, 12:04 PM   #2
Ed_Strong
Ed_Strong's Avatar
Ed_Strong Normal reputation
Re: Front brake pads
That means your caliper piston is not retracting, hence when you stop putting pressure on the brake pedal, the piston is not relieving pressure from the inside brake pad making it drag on the disk and causing it to wear at a faster rate than the outer brake pad.
They sell caliper piston kits to do an overhaul on your existing calipers, but for the price I think you're better replacing the whole caliper assembly with new ones.
Current Rides:
2005 Chevrolet Malibu LS - 3.5L V6 SFI -{|}- 2000 Ford Windstar LX - 3.8L V6 SFI
________________________________________
Past Rides:
1991 Chevrolet Corsica LT - 3.1L V6 MFI -{|}- 1995 Dodge Grand Caravan SE - 3.3L V6 MFI
1980 Ford Mustang - 3.3L L6 1BBL
Ed_Strong is offline   Reply With Quote
Old 08-11-2008, 03:01 PM   #3
iBgodsmacked
iBgodsmacked Normal reputation
I agree with you, but you may not have to do a complete dissasembly. It doesn't have to be the piston not retracting, i have found that the slide pins need to be lube up. pull them out before you do your overhaul and inspect them, if the are rusty and dry. lube and try them.
iBgodsmacked is offline   Reply With Quote
Old 10-05-2008, 12:38 PM   #4
Searchlight
Searchlight Normal reputation
or it could mean that the guide pins are not properly cleaned and lubed with HIGH-TEMP grease....
Searchlight is offline   Reply With Quote
Old 10-05-2008, 01:13 PM   #5
Scrapper
Scrapper Normal reputation
i agree on the caliper not sliding or not sucking pistion back in. or it could be pins like he said not letting it slide right and make sure where caliper slides make sure it's not rusty if so clean those off.
Scrapper is offline   Reply With Quote
Old 10-05-2008, 07:16 PM   #6
CoolasIce
CoolasIce Normal reputation
I've cleaned and thoroughly lube the pins on my car, and the inside pad still wears more than the outer. You gotta be careful. You can't see the inside pad wearing, so it might wear down to nothing and chew up the rotor.
CoolasIce is offline   Reply With Quote
Old 10-09-2008, 07:22 PM   #7
Speedy_1234
Speedy_1234 Normal reputation
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Just change the calipers
opcorn:
Speedy_1234 is offline   Reply With Quote
Old 10-15-2008, 11:43 PM   #8
AD2BU
AD2BU Normal reputation
I've also found that the hose can degrade internally and prevent the brake fluid from returning to the system after releasing the pedal. If you replace the caliper, spend the extra 5 mins. and a few bucks and replace the hose as well.
AD2BU is offline   Reply With Quote
Bookmarks
Google
Web AF
