Re: 1996 Impreza has FWD Light on Dash?Whats Wrong?
The FWD light is telling you the AWD system is not engaged. There's a fuse somewhere (can't recall if it's under hood or under dash, but it's marked on the lid) that need to be pulled back out to go back to AWD mode.
For OBD1, I'm told the code-read procedure is to look under the dash for the two green plugs, and plug them together. This puts the ECU into diagnostic mode, and the Check Engine light itself will flash out in a pattern that is the code. Make sure you disconnect the test plugs before driving again.
