What Are You Running?Self 03-11-2003, 09:51 PM Curious as to what everyone is driving, what mods you have done, what kind of power you're pushing, and what kind of times you're running...This will settle once and for all what people run so they'll be no confusion and such!! Self 03-11-2003, 10:21 PM Actually...Decided to move this to the AF.com General Street Racing forum. Head over there and let us know whatcha got!! TerminalVelocity 03-11-2003, 10:30 PM 2 cars and my boots! -The Stig- 03-11-2003, 10:40 PM 1972 Chevy Nova Motor Dyno'd at: 423hp @ 5500 RPM 437ft-lbs of Tq @ 4500 RPM Blue Printed and Balanced 383ci or 6.3liters 350 4 bolt main w/400 Crank Comp Cam Extreme Energy Hyd. Cam .477"/480" Lift, 224*/230* @.050 268*/280* Adv. Dur., 110 L/C Comp. Cams Roller Tip rocker arms Dart Iron Eagle Heads 200cc Intake Runners 2.02"/1.60 Valves Edelbrock RPM Airgap Intake Manifold Holley 750 CFM Carb Double Pump Mechanical Secondaries MSD Distributor and Ignition w/ 6000rpm Limitor What I hope to also run... Hooker Headers Competition Headers B&M Turbo 400 B&M Holeshot 2400RPM Converter B&M Transpak Shift Kit 12-Bolt Posi w/3.73 Gears Magnaflow Mufflers The B&M Th400 might get swapped for a TCI TH400w/Trans-Brake Nitrous setup might be in might also be in the lineup... still deciding But, I do know a Holley StealthRam MPFI system is in the future for the car... Oh so cool. Yep, With all said and done... should be pushing the car deep into the 11's. :bloated: TatII 03-11-2003, 10:42 PM today in lab class i hooked up the scan tool on to my car and realized that i was only running at 88% throttle opening when i floor it. after i adjusted my throttle cable, i'm at 91% throttle opening. before i discovered that problem i was running a 15.5 on 1/4 on my g tech meter. mods: brembo brakes aem intake randomtechnology high flow cat apexi n1 dual asp crank pulley b & m short shifter nismo shift knob *it actually changes the shift characteristics* denso iridium spark plugs THE ARS 03-11-2003, 10:42 PM 1986 Regal Te44 fuel system, IC, cam, tranny, dr's. 12.02@118.7 TatII 03-11-2003, 10:49 PM that year regal is basically a n/a grand national right? fatninja19 03-11-2003, 11:49 PM I think the dude isn't from the US.... -The Stig- 03-12-2003, 12:01 AM Last time I checked Massachusetts was still part of the United States... ;) And you could have a Turbo Regal that wasn't a Grand National... Jimster 03-12-2003, 12:17 AM Alfa Romeo 156 2.5 V6 Sportivo Removed bodykit Panasonic Head Unit 18 inch Alfa Romeo sport wheels 2.5 inch exhaust system Remus muffler 4 into 1 Extractors K & N Pod filter K & N Intake Coming soon: GTA suspension and new pistons It runs 14.87@109mph THE ARS 03-12-2003, 01:10 AM It's a turbo. It has a vinyl roof and a bench seat. It's funny how slow it looks, and how fast it goes. It has a bump in the hood and aluminum wheels. It has dual exhaust (mine does). It has a column shift auto. It goes 12.02. Beware American technology. RazorGTR 03-12-2003, 01:18 AM Mines in the signature and if I can this weekend coming may take it back down the strip. With the recent increase in power and a prepped track should see 11's. GTStang 03-12-2003, 01:39 AM 12.56 1/4mile New England Dragway Epping,NH Never Dynoed All the big items listed below. 90CorollaSR5 03-12-2003, 02:30 AM i've probably got below 100 hp/torque, most likely quarter mile in 18 seconds or more :). Don't think i'm gonna do any mods until i can afford a 4A-GE 20 valve, 4A-GZE or a Formula Atlantic engine swap ;). 450HPviper 03-12-2003, 10:16 AM I would rather not say:D Self 03-12-2003, 10:17 AM Originally posted by 450HPviper I would rather not say:D Hah, well you're not fun then!:p -The Stig- 03-12-2003, 02:51 PM Originally posted by 450HPviper I would rather not say:D Well, if you really do have a Viper with 450hp... then it's pretty much stock... right? C'mon.. tell us.... What cha runnin? Dont be Skeered! Layla's Keeper 03-12-2003, 03:19 PM Okay, these power numbers are rough estimates. But they're based on the best information I have. 1970 MGB GT 1.8L OHV inline four. (yes, pushrods) Aluminium head, iron block. Solid lifters, 8.8/1 compression pistons. ANSA 4into2 header & stainless steel exhaust. used Weber 2bbl carburettor (4CV model, if I'm not mistaken) Rough power guestimate: 170hp. Not bad in a car as light as my Layla. And by the way, she's never EVER going to see a dragstrip. 12seconds of racing is not my idea of fun. -The Stig- 03-12-2003, 03:48 PM Originally posted by Octagon Okay, these power numbers are rough estimates. But they're based on the best information I have. 1970 MGB GT 1.8L OHV inline four. (yes, pushrods) Aluminium head, iron block. Solid lifters, 8.8/1 compression pistons. ANSA 4into2 header & stainless steel exhaust. used Weber 2bbl carburettor (4CV model, if I'm not mistaken) Rough power guestimate: 170hp. Not bad in a car as light as my Layla. And by the way, she's never EVER going to see a dragstrip. 12seconds of racing is not my idea of fun. thats if little Layla could get her little bumm through the lights in under 12 seconds ;) Not to mention the traction problems you'd probably have dumping the clutch to run such a time... hehe But we know Layla isnt built for the mighty:rolleyes: quarter mile... she's been put on this earth to go around corners at break neck speeds! Go handling go! Layla's Keeper 03-12-2003, 07:10 PM Originally posted by RedNeck383 thats if little Layla could get her little bumm through the lights in under 12 seconds ;) But we know Layla isnt built for the mighty:rolleyes: quarter mile... she's been put on this earth to go around corners at break neck speeds! Go handling go! 15seconds, and smoking those 4inch wide bias-plies all through second gear. You hit the nail on the head. Though I bet that if I could get a reasonable price on a lug-spindle (as opposed to wire spindle) MGB GT and a Rover V-8, then I'm sure that 12seconds won't be too far off. Misundaztood 03-12-2003, 08:15 PM 97' Eclipse GS. Mods are in sig. What's she running? Bout' 10 seconds.:coolguy: ...from 0-60...:( :cry: k_dog 03-13-2003, 06:42 AM 93' Toyota GT-Four TRD 2.0 16valve DOHC Turbocharged AWD 225bhp@3500rpm Redline-6500 Top Registered Speed-160 Actual Top speed Reached-135 (dont ask:rolleyes: ) No real body mods except for a rear wing for added downforce. OZ Wheels Sparco Seats&Harnesses Engine:(not much) TRD Lightened Camshafts and Gears HKS Air Intake TRD Stage 2 twin plate clutch TRD Coilovers This IS a rally car so, I've never really done any street racing. Every time I get chalenged, they say "where do you wanna go?"....and I take them to a haul road....lol Brian 76_cobra 03-13-2003, 10:03 AM You can probably guess what kind of car I drive....I wonder what gave it away?:D Ford 5.0L Crate motor 285hp ( underrated) I read an article in muscle mustang and fast fords where they dynoed my same combo at 300hp at the flywheel Mods are heddman long tubes 2.5in exhaust all the way back to dual flowmasters, 2.5in Dr. gas X-pipe, 2in carb spacer. no1/4 yet but sometime in may. HiFlow5 0 03-13-2003, 11:05 AM Originally posted by Misundaztood 97' Eclipse GS. Mods are in sig. What's she running? Bout' 10 seconds.:coolguy: LOL I was like what the??? Then scrowled down and saw this ...from 0-60...:( :cry: I was runnning mid 13's on street tires and no traction. I should be in the 12's this spring after I get my new suspension set up. BLU CIVIC 03-13-2003, 11:21 AM ok let me put myself out there under the spotlight.....no engine mods....just suspension mods and with the d15b1 engine in my 90 honda civic hatchback standard making 70hp and about 59 to the wheel...i believe with my 4-speed tranny i'll probably be running....i dunno....+18 at the track.....gotta take the '00 Durango SLT Plus out to the track and see what it runs TDIguy 03-13-2003, 12:03 PM 2003 VW Jetta GLS TDI Upsolute chip .205 injectors larger pumps Pipercross intake Dieselgeek short shifter Geek Oil cooler Geek shifter Geek flywheel Qauiffe LSD 181 whp, 400 ft-lbs (now) 0-60 under 7.6 seconds average 1/4 getting closer to high 14's and low 15 Having major traction problems. Must start in 2nd, peels bad in 3rd Self 03-13-2003, 02:42 PM Originally posted by TDIguy 2003 VW Jetta GLS TDI 181 whp, 400 ft-lbs (now) 0-60 under 7.6 seconds average 1/4 getting closer to high 14's and low 15 Having major traction problems. Must start in 2nd, peels bad in 3rd What the heck? How do you have so much torque? k_dog 03-13-2003, 02:45 PM That IS alot of torque for a 1.8?!?!?! Brian TDIguy 03-13-2003, 02:47 PM Turbo Diesel k_dog 03-13-2003, 02:48 PM Originally posted by TDIguy Turbo Diesel In a Jetta? How'd you manage that? Brian Self 03-13-2003, 02:49 PM I don't get it???:confused: TDIguy 03-13-2003, 03:06 PM Sorry brain fart 171HP and 325 ft-lbs is the accurate number k_dog 03-13-2003, 03:08 PM I have 225bhp and STILL only get 200lbs of torque....and I have a Turbocharged AWD 2.0?!?!?! Brian TDIguy 03-13-2003, 03:15 PM Originally posted by k_dog I have 225bhp and STILL only get 200lbs of torque....and I have a Turbocharged AWD 2.0?!?!?! Brian DIESEL TDI's are 1.9 8valve not 1.8 20valve Stock 90hp 155ftlb check out www.vw.com Self 03-13-2003, 04:47 PM I don't get it still???:confused: How'd you get 200 extra lbs-ft of torque? fatninja19 03-13-2003, 05:39 PM 90Corrollasr5: Can you tell me what the Formula Atlantic swap is? TDIguy 03-13-2003, 05:39 PM okay Stock 90hp 155ft ECU upgrade (upsolute) 125hp 230ft .205 injectors 150hp 280-290ft 520pp pumps 170-/+hp 310-320ft Go have a look at http://forums.tdiclub.com/postlist.php?Cat=&Board=UBB4 Firebird 03-13-2003, 05:52 PM '90 Firebird, 350 crate motor ('91 Caprice), k&n filter, catco C-converter, JET chip and the full interior it ran a 15.8 @84. I just got done putting in 350 truck injectors, and ripped out the back seat and back carpet and spare tire and took out most of the big stereo stuff that was in there. also getting a set of BFG drag radials instead of the radial t/a's to see if we can get it to hook up, and I got a shift kit that waiting for warmer weather to be put in ;) I'm guessing mid-low 15's and touching 90mph, hopefully. saving up for a cam and a new intake, and gonna port and polish the heads to try and make it into the 14's. Polygon 03-14-2003, 07:42 AM Just click the links in my sig to find out. bigfrit 03-14-2003, 07:46 AM BMW 325 Ci 170 Hp, 240 Kph Blazing fast and cool car, if I say so myself ! Olivier 90CorollaSR5 03-16-2003, 01:07 AM FatNinja: The Formula Atlantic engine is a highly tuned 4A-GE. Its a 1.6 liter naturally aspirated engine producing 240 hp@8500, 136 torque@7600. Its used in the Toyota Formula Atlantic Series. I'm never gonna own one though because they are quite expensive.. ;) fatninja19 03-16-2003, 01:21 AM Wow.. those are quite impressive numbers!! How does it cost about? ANd do you have to run race gas?? RazorGTR 03-17-2003, 01:16 AM Here is my GTR Launching its nuts off ! Oh yea before the comments I miss a perfect light by smidge. .489 on a .5 light, DOH http://www.defy.net.nz/albums/album38/IMG_0916.sized.jpg Spyk 03-17-2003, 05:56 AM Arre we talking 60' time i like that cause i dislike awd withha passion.. how about this the Auot (art carr built tranny) Ws6 with stal/ prperstr/ shiftkit, gears and nitto's 1.5x every time i've never seen 1.6 or higher as for 1/4 mile i won't bore you with out usning the Nos on both hi-po gm's Ws6 11 flat Zr1 11.5 Roadmaster (LT$ clicl under .. well 13 flat Sentra 14.4 Jeep.. great improvement in its 0-60 6.9 vs stock 9.8.. gottat love 4 wd trucks though.. i mean they have a purpose lets see a skyline/wrx/ eclipes tow 7000 lbs with 245 hp have a nice day boy smoke you soon RazorGTR 03-17-2003, 09:01 AM Originally posted by Spyk Arre we talking 60' time i like that cause i dislike awd withha passion.. how about this the Auot (art carr built tranny) Ws6 with stal/ prperstr/ shiftkit, gears and nitto's 1.5x every time i've never seen 1.6 or higher as for 1/4 mile i won't bore you with out usning the Nos on both hi-po gm's Ws6 11 flat Zr1 11.5 Roadmaster (LT$ clicl under .. well 13 flat Sentra 14.4 Jeep.. great improvement in its 0-60 6.9 vs stock 9.8.. gottat love 4 wd trucks though.. i mean they have a purpose lets see a skyline/wrx/ eclipes tow 7000 lbs with 245 hp have a nice day boy smoke you soon I think you need to quit smoking period mate :p If your getting 1.5's 60' times your car should have enough poke to run mid to low 10's especially with a slush box. :rolleyes: HiFlow5 0 03-18-2003, 05:21 AM Originally posted by RazorGTR I think you need to quit smoking period mate :p I think he should have spent more money on rehab then that shopping list of cars. :rolleyes: Hey nice launch RazerGTR! Looks like you hooked pretty well. What were your 60' times? Layla's Keeper 03-18-2003, 03:05 PM Jeez Razor! That's sickness in the enth degree. I'm dead chuffed seeing that out of an R32. You have much kudos and big cajones. I am impressed. :angel: fatninja19 03-18-2003, 05:45 PM Originally posted by RazorGTR If your getting 1.5's 60' times your car should have enough poke to run mid to low 10's especially with a slush box. :rolleyes: OUCH!!! Self 03-18-2003, 08:59 PM Where are you located, Spyk? RazorGTR 03-19-2003, 09:53 AM Originally posted by HiFlow5 0 I think he should have spent more money on rehab then that shopping list of cars. :rolleyes: Hey nice launch RazerGTR! Looks like you hooked pretty well. What were your 60' times? My best on the day was 1.688 and ironiclly I did not have my quickest pass as third was getting pretty buggered by then or at least I thought. It seems I may have a slightly bent shifting fork as under normal driving no issues going into any gears weird. I was leaving the line at 5,700 rpm and had virtually no wheel spin. As you can see from the photo she was trying her hardest to pull the front wheels completely off the ground. Not too bad for daily used street tyres. Supra650RSP 03-19-2003, 12:30 PM Some of my info is in the sig: 631rwhp @ 24 pounds of boost off bottle Best run was a 10.32 @ 146 m.p.h. on slicks on bottle Just bought a Skyline though and a massive turbo for it...hoping to blow the Supra off the track by August. It will be halfway done for the Hot-Rod Power Tour at the end of May so if you all are around come see it Automotive Network, Inc., Copyright ©2012
